Ok, I have a 2011 outback 2.5 CVT with about 150k. Problem is cylinder 3 & 4 misfires when letting off the throttle. Cruise down the road steady throttle let off throttle and that’s when it misfires. Here is what I have done/checked. New plugs and Subaru coils. New crank sensor, cam sensor, crank sprocket, cam sprocket, checked timing, checked valve lash, compression and leak down were both good, smoked intake, checked for dropped valve guides, new air fuel ratio sensor, new rear o2 sensor, new mass air flow sensor, air filter is good, head gaskets test good, swapped injectors front to back and side to side, checked fuel pressure, updated ecm and tcm with latest Subaru programming, knock sensor, cleaned and relearned throttle body, ran it with no exhaust to make sure it wasn’t plugged, new pcv valve assembly. I work on these cars every day and I have yet to have a misfire that I couldn’t identify the problem pretty quickly. The only time I can get the car not to misfire is with the air fuel sensor unplugged which causes fuel trims to default to about +25% I have combed through hours of data and cannot find the issue. I know I am missing something but I can’t find it. Torque converter maybe shuddering causing the knock sensor to misinterpret a miss? Fuel trims do go a bit lean when letting off throttle but not leaner than another car of same model. Any insight? Anybody run into this before? I have never seen this particular issue and it is driving me insane...
