I have been considering the OEM remote starter for awhile now but have been disappointed by the fact that it turns off when the door is opened. Several people have disconnected the drivers door switch and successfully inserted the key and have the car remain running..ala aftermarket remotes. With that info I was on a quest to find a "workable" solution and I think I may have.
We need to be able to interrupt the wire that provides a ground input when the door is open to pin C14 on the BIU (Body Integrated Unit) under the dash ....but only while the remote starter is active! My solution involves a time delay relay and a regular relay. The time delay relay, TDR, is from here: Automotive Time-Delay Relay It allows for either a pos or neg output, two input triggers, pos or neg, and a 12v supply. My proposal is this:
Connect a remote start active Acc 12v to this TDR. Trigger it with a pulse from the Driver's door lock pin D4 on the BIU. Use the pos output (for up to 120sec) of this TDR to activate another standard 12v relay to interrupt the driver's door switch wire at BIU pin C14.
This gives us an interrupt for a set period of time up to 120 sec after the driver's door is unlocked but only when the car is running. So you remote start your car, unlock your door insert the key within up to 2 min and drive away, after which the door switch returns to normal operation. If the car is not running, the switch will work normally and the interior dome light will work.
Does this look like it will work? If I had the OEM starter I would try this but I don't want to get one until I have a solution. I have attached a handwritten schematic for those who are interested.
