ive read online there are excessive oil consumption on OUTBACK 2014, does the newer and current model have same engine ? does the problem really happen
thanks and cheers
Don
thanks and cheers
Don
My wife has a '14 Forester and I have a '15 OB, both with the 2.5.
Here car uses a quart between changes. Mine uses a negligible amount. A quart between changes is not excessive.
Haven't experienced any oil issues yet but regarding the discussion about whether or not excessive consumption is normal, this article states that the excessive oil consumption was a result of systematic design flaw.
And that article is saying that this is not normal (though some manufacturers obviously disagree):My point is that a lot of manufacturers are experiencing oil consumption issues and around 1 quart between changes is not considered excessive.
Excessive Oil Consumption Isn't Normal - Consumer Reports
Honda owners won their class action suit because the extra oil use was a result of a design flaw. Subaru owners won their case and it was discovered that defective piston rings caused extra oil to burn. I believe the gen5 OBs are excluded from that particular suit but still, 2% of a 500k sample size is the exact definition of "abnormal".Consumer Reports said:Not all engines suffer from this problem. In fact, our data shows that owners of 98 percent of 2010 to 2014 cars did not have to add oil between changes. But the cars that do burn oil do so furiously.
They'll look completely fine. My GM truck uses more than 2 quarts in 3,000 miles and the plugs didn't look unusual when I changed them last year. The oil/fuel ratio is very very low if you burn a quart in 5,000 miles.Can't wait to see what the plugs look like...
Back to the OP's question...ive read online there are excessive oil consumption on OUTBACK 2014, does the newer and current model have same engine ? does the problem really happen
