Ok I just bought a 2011 subaru outback a few months ago and a month and half ago started overheating thermostat was stuck closes boyfriend changed it boiled it in water still good. Did fine a few days started again he thinking hg but maybe water pump another mechanic said it's the water pump no way at all is it the hg. So now I buy a water pump and pay mechanic almost 500 to put on he also replaced the new thermostat because apparently it was stuck closed. Now 2 days later hose from radiator and overflow tank starts coming off every couple days so boyfriend said it's still good and clamped it on. Did ok for a bit then I start noticing bubbles in overflow tank and now for the last 2 weeks my overflow tank keeps filling and overflowing bottom hose staying cold I see it could be clogged radiator by now I'm fed up with being pulled around because now everyone keeps saying without looking it's hg just because subaru is known to have hg issues. So I just learned to flush my radiator clean my overflow tank but I tried bleeding radiator but it's like endless supply of air bubbles without cap overflow stays normal thermostat opens and closes and no overheating but after an hour I still had air bubbles coming out I gave up put cap on and overflow tank starts to receive coolant and bubbles so I shut car off.
Now my car has had no smoke motor is nice and quiet until it starts to overheat there was no oil in coolant no coolant in oil the white stuff under oil cap no check engine light no misfires and the bubbles under radiator cap look like boiling bubbles they are not frothy looking there has been absolutely nothing else indicating hg except air and overheating which can be many other things.
If I have to learn to replace hg I will but want to see if anyone else has experienced this issue or have an idea what it may be other than hg. Or maybe tip on actually getting air out. My car doesn't have bleed valve or screw so had to bleed from radiator. I read a few say air can circulate back in through funnel to cover top but nothing else said to cover the top.
