P0301,P0303,P0305 At the same time!
9.4K views 18 replies 9 participants last post by  YeuEmMaiMai
I know that individually the P0301,P0303 & P0305 are cylinder misfire codes. But what would cause all three in one bank of cylinders to register a misfire at the same time?
Thanks in advance.
Thanks in advance.
bad would be head gaskets. maybe a fuel rail issue though. or a o2 sensor.
ever overheat ?
#15 ·
#19 ·
you will most likely get a p420 or fueling error code or a heater circuit problem. Misfires on one bank are typically VVT solenoids. I did mine at 160K and it cleaned my idle right up on my 3.6R. no matter the miles on your oil change, Subaru and other manufacturers state to change oil with VVT solenoids. I did just that.
