Pitch Stop Mount Install Help
4.1K views 8 replies 6 participants last post by  SilverOnyx
I picked up a Cobb Tuning pitch stop mount but I've never installed one before. In preparation of the install I'd like to peruse some instructions before jumping right in. I'm having a hard time finding anything for a Gen 6 Outback. I have watched some install vids on WRX models so I get the gist of what is required, but I'm not sure I know how to remove the TMIC properly in the '20 Onyx XT.
If anyone can share a guide, video, or perhaps even just offer up some tips, I'd be tremendously grateful.
Removing the IC was actually not terrible for me. First remove all 4 (possibly 5) bolts holding the IC down. Next follow the plastic IC hose down about halfway, IIRC it was on the left hand side of the car. There's a hoseclamp holding it together there...just loosen the clamp enough to rotate the entire IC assembly up and to the left. This should give you access to the pitch stop behind the IC. Don't fully remove the clamp as it will probably be slightly indexed in to the hose itself, I didnt want to remove the whole assembly so i just rotated enough to get access behind it.
I hope it's not too late but there is an easier way to do the pitch stop - the intercooler has a metal clip and the entire thing can be removed - I have illustrated it in a post.
I am the one that found information saying you needed to replace the gaskets since they are single-use items, but when I took mine off I didn't use new gaskets - the car is new enough that I think the gaskets are fine, I took off my intercooler twice, it's not leaking - boost is strong, so no worries.
If you want I can dig up the gasket part numbers for you
