Rattling sound from engine
7.7K views 8 replies 7 participants last post by  Biebs
Background
From basically the start of the life of my 2013 Subaru Outback 2.5i, occasionally I would hear a rattling sound coming from my engine.
- it normally comes when my car has been running for at least 10 minutes
- it can occur from acceleration-from-a-stop
- it can occur even on acceleration-on-highway
I'm normally pressing light/medium on the throttle.
Diagnosis
Subaru dealership service listened to the problem; they advised I should change my brand of gas (note: not the octane level from 87).
- I had been using QT gas [quite popular in Arizona]
- I switched to Chevron gas [popular in Arizona and California].
I notice the rattling has gone down quite a bit; but it still happens from time to time.
1. Has anyone else experienced this problem?
2. Does anyone have any advice?
Currently at about 73k miles on my vehicle; averaging about 34k per year.
Thanks in advance for any feedback.
The heat shields will rattle and can sound like the end of the world on acceleration, often a bolt has rusted out or gone missing. When cool you can get under and check them pretty easily. Otherwise not the subaru piston slap? That is pretty common but not a rattle.
gas is extremely unlikely to be the issue - and a dealership can retrieve knock events and timing , etc. so, they should know better.
Now, IF a knock sensor is bad, high octane fuel 'may' improve the symptom, but on a 4cyl engine it is not a a 'fix'.
Some 6 cylinders need high octane.
My 2 cents
Being in Arizona doubt you have rusty heat shields.
Does this seems to happen in hot weather??
I would go to a 5-30 motor oil
