Hello. 2005 Subaru Legacy Outback, 2.5 4-cylinder, no turbo. 120,000 miles.
Started running rough within the last month. Felt like a miss and rough idle when stopped but still in gear. Unsuccessful OBD scan.
Check engine light finally came on the other day with cruise light blinking. OBD scan showed cylinder 3 misfire.
Original spark plugs. Replaced with new NGK plugs today. Oil came out with three of the four plug wires. Recognized that valve head gaskets will need to be replaced soon. The 4th plug wire was semi-hardened with a rust/burned appearance. Still flexible but it appears that new wires should be considered also.
Check engine light now gone as well as blinking cruise light. Idle is fine in gear but now car runs more rough in gear when stopped and starting dying.
Basic repair knowledge but mainly American cars (Pontiacs). I wouldn't think my changing of the spark plugs would exasperate the idle problem but maybe I messed something up? Leaking valve gaskets won't do this, would they?
Something else related to the cylinder 3 misfire I should be considering? I have a reliable and affordable Subaru mechanic in the area but anything I can fix is always nice for the pocketbook.
Thanks in advance.
Thanks in advance.
