Hi,
I've got a 97' Impreza Outback Sport and I'm trying to pull the codes using the "secret handshake" method. For some reason after countless tries it's not working. I tried it several time with no luck. I followed the steps one by one. Is it something that needs to be done quickly?
I've warmed up the engine
turned the key to off
Turn the key to on
Started the car
Drove above 12mph
Stopped the car ( by this I've only come to a complete stop using the brakes.)
-do I put the car in park or something at this point? Also my foot is already on the break leading into the next step, right?
Stepped on the brake and put it in 1st
Turned the key as far off as I could (since it's in first it doesn't go to the lock position.)
Turned the key to on
Moved to 2
Moved to 1
Moved to 2
Moved to 3
Then to D.
(Do I leave my foot on the brake during the last 5 steps?)
All the light are lit on the dash but the AT Oil Temp light doesn't blink at all.
Any ideas?
Turn the key to on
Started the car
Drove above 12mph
Moved to 2
Moved to 1
Moved to 2
Moved to 3
Then to D.
Any ideas?
