Spark Plug and Coil Removal 2.5XT Turbo
1 reading
35K views 5 replies 3 participants last post by  gilman12
I made an attempt to change spark plugs in my 2006 Outback 2.5 Turbo today. Actually took off enough parts to get to them. I took the coil off of the front driver side plug as it was the easyist to get to and could not get the coil out of the hole. The frame is inches from the plugs and does not allow enough room to get the coil out. With the coil still in the hole there is no way to get to the plug. The other coils are even closer to the frame rails. Any suggestions. Also, the manual I bought (pretty much useless) said the gap on the turbo is .028 and the owners manual and sticker under the hood are also useless for gap but this is extremely tight.
The only thing I would add is take your time and don't get frustrated. I know it seems like you have to pull the engine to get the spark plugs out, but I assure you that is not the case. They will come out but you will have to twist and turn them upside down to get them out of certain places. Yes I am at stage 2, thats why I went a step colder.
