Folks, my search feature is not working...or else I don't understand how to do it! Otherwise I'm sure somebody has done this/experienced this already...
2003 Outback with 100K on it. Already replaced the driver's side inner tie rod end because of boot deterioration from exhaust heat and subsequent dirt entry/wear. Replaced passenger side CV axle assembly because of boot deterioration from exhaust heat. Now I noticed a bit of "looseness" in the front end, and could hear and feel a little clunk now and then. I jack up the car and shake the passenger wheel side to side and can feel the looseness. I figure it is the other inner tie rod end. I pull the deteriorated boot out of the way and the tie rod end is fine, it is the rack and pinion shaft that is moving around. There is a little bit of steering fluid leakage as well.
Time for a new remanufactured steering rack, is it not?
Any tips or how-to's on this topic?
I'm getting a bit frustrated with this vehicle...it is not aging well. And I need to do a timing belt in 5K miles too. I should have sold it at 95K miles!
Joe
Joe
