Suddenly missing outside mirror cover - best way to get a replacement painted?
4.3K views 27 replies 11 participants last post by  thejakebarnes
I noticed that I somehow lost (or maybe 'lost', as in someone else needed one) the right-side outside mirror cover on my 2013 Outback. I believe I have found the correct part on the online fiche (p/n 91059AJ00B) but it does not appear to be available in a painted version. The part itself isn't too outrageous (about $35) but I'd hate to have to pay multiples of that just to get it painted at a pro shop, although I guess i don't have any other option (short of a spray can but I think I know how that would end up looking.)
Also does the replacement simply snap into place? There doesn't appear to be any other damage to the mirror assembly.
TIA for any tips -
#5 · (Edited)
Thanks for the suggestions. I'm actually kind of curious how well some Duplicolor and clear coat would work and given the $30 cost of the part it won't cost me much to find out. Best case is that it's passable and worst case it is looks like someone took some Duplicolor and did a hack job, in which case it won't cost much to start over and will have learned something as well.
Still wondering how I lost it. There appears to be zero collision damage so wondering if someone 'liberated' it. Better that than my cat converter I guess.
If you go with the flat black color that @Dubz suggested and skip the clearcoat, it will give you two advantages:
  1. It won't look hack.
  2. It's easy to retouch, if needed, without having blending issues.
Some body shops will make up a spray can of colour matched paint using your paint code. If your original paint is faded, it might not be as close as you'd expect.
I'm not expecting it to be that close ;) Seriously, the car has been garage-kept since new so no significant fading, plus the mirror is not like having to match a body panel and close might be good enough to pass casual inspection. It basically comes down to do I want to risk 30 bucks plus a can of Duplicolor to see how it turns out. My expectations are low but you never know.
My buddy lost 2 red mirror covers on his Malibu. First painted replacement cost $75 at Chevy. Second was $18 (black) from EBay. It will stay black and not really noticeable.
#14 ·
That option is NOT cheap!
True, but it's not "multiples" of the part cost when painted by a body shop. I still think a salvage yard is one of the better options when it's convenient (i.e. not too far away) assuming you will find one of the right colour. Quite likely cheaper than any new replacement option and already painted the right colour to boot.
#15 ·
I'm slightly confused because the side mirrors on my Dark Blue '14 OB are Silver. What are yours, and what colour are the "unpainted" ones?
You may end up liking them unpainted 😁
Kindest Regards,
JD
#16 · (Edited)
In my area I would very surprised if I could find a body shop that would provide time and materials for such a job for much less than $100, and that is 'multiples' of the $30 cost of the part. The junkyard option might be less (assuming that you could find a yard with the right color and willing to separate the cover from the mirror assembly), but considering time to find/driving miles/etc. I'm not sure the final cost would be much less than other options.
On my 2013 the mirror covers were color-matched from the factory (Venetian Red, H2Q, in my case), maybe was part of an option package, not sure. The unpainted are black so yes, one could probably use them as is if you don't have to have color-matched mirrors (and I don't.) But in the end I'll probably just end up biting the bullet if I can find a reasonable painting option.
#23 ·
I don't think so. Given the price of paint I'd say the $100 mentioned is way too low. Most shops wouldn't want to be bothered with this and the chance that you whine about imperfect colour matching, so even if they'd take it on I'd say more like $250 - $300. Plus you're done it an hour after masking and all. Take it to a shop and you're without your car for a day.
It's not just the paint, which when you mix in very small amounts is harder to nail down the exact quantities. Someone mixes paint, loads the gun, puts on the apparel, goes into a spray booth, hangs and paints the object, has to clean out the gun nozzle and gun container and the mixing container. To say nothing of the power used to light the paint booth and run the fans plus anything else like masking off. No way anyone will do that for 100 bucks including the cost of paint.
#27 ·
I received and installed the unpainted part, and since the body cladding and pillars are blacked out the black mirror housing almost matches better/looks better than the painted. On the fence whether it's best to paint the new cover or just replace the driver's side with unpainted for a small cost. In fact it I sold the painted cover I'd probably be dollars ahead on the whole deal.
