tranny question..01 H-6
4.8K views 3 replies 3 participants last post by  Garth
I have the ll bean modle...what year trannys will work with my car? I was hopeing 01-04....thanks! garth
I've seen this question asked several times, and have not seen a solid answer.
I've heard its just like any other 4EAT but it has slightly different gearing.
That would mean, I think, that you could put in any 4EAT, but then the front pumpkin gearing would not match the rear, you'd have to change the rear gears as well.
Since I might need a trans at some point, I'm hoping a definitive answer emerges.
Dave
This is what I have found out with regards to your dilemma..
Open the hood, and look at the transmission from the driver side. You should spot the transmission # from there.
For my 04 Outback H6 (35th anniv. non-vdc) it's a TZ1A4ZMFAA
I got this link in google:
http://www.endwrench.com/oepropdf/remanufactured.pdf which lists what reman'd part numbers you can use for your tranny.
Here's a snippit of the important part (and I'll bold all the 6 cyl versions):
1st column I would presume to be manufacturing date,
2nd column is the actual reman'd tranny part # you would order from Subaru,
3rd column is the notes (and also includes the tranny #, so please double check with what you have).
Hope that helps.
200007-200104 31000AE050R1 3.0 OBK 6 FOR VDC TV1A4YVCAA
200007-200104 31000AE330R1 3.0 OBK 6 EXC. VDC TZ1A4ZVCAA
200007-200104 31000AE330R1 3.0 OBK 6 LB TZ1A4ZVCAA
200105-200204 31000AE820R1 2.5 BRI + L TZ1A4ZCDCA
200105-200204 31000AE810R1 2.5 SUS# + OBK# TZ1A4ZCDBA
200105-200204 31000AE600R1 3.0 SUS 6 + OBK 6 FOR VDC TV1B4YVDAA
200105-200204 31000AE640R1 3.0 SUS 6 + OBK 6 EXC VDC TZ1B4ZMDAA
200105-200204 31000AE800R1 2.5 GT# TZ1A4ZCDAA
200105-200204 31000AE640R1 3.0 OBK 6 LB. TZ1B4ZMDAA
200201-200305 31000AF260R1 2.5 BRI + L TZ1A4ZCECA
200201-200305 31000AF250R1 2.5 SUS# + OBK# TZ1A4ZCEBA
200201-200305 31000AF490R1 3.0 SUS 6 + OBK 6 FOR VDC TV1A4YMEAA
200201-200305 31000AF500R1 3.0 SUS 6 + OBK 6 EXC VDC TZ1A4ZMEAA
200201-200305 31000AF500R1 3.0 OBK 6 LB. TZ1A4ZMEAA
200201-200305 31000AF030R1 2.5 S/S TV1B4YCEAB
03 31000AF500R1 3.0 SUS & OB
03 31000AF490R1 3.0 SUS & OB VDC
04 31000AF730R1 2.5L GT SPORT SHIFT VTD TV1B4YCFAB
04 31000AF760R1 2.5L GT SPORT SHIFT VTD P-ZEV TV1B4YCFBB
04 31000AF740R1 2.5L SUS, OUTBACK, AND BAJA TZ1A4ZCFAC
04 31000AF770R1 2.5L SUS AND OUTBACK P-ZEV TZ1A4ZCFBC
04 31000AF720R1 2.5L “L” AND Brighton TZ1A4ZCFAA
04 31000AF750R1 2.5L “L” AND Brighton P-ZEV TZ1A4ZCFBA
04 31000AF780R1 3.0L SUS AND OUTBACK TZ1A4ZMFAA
04 31000AF790R1 3.0L SUS AND OUTBACK VDC (VTD) TV1A4YMFAA
