Transmission identification
14K views 16 replies 4 participants last post by  eagleeye
Hi!
My 2000 Outback 5 speed is moaning at freeway speeds & the fluid was metallic last time I changed it. I've discovered some play in the front diff between the front axles, I suspect this is where the problem is.
I was curious if anyone is familiar what to look for as far as compatibility goes. What range of models, years and makes, transmissions will work in a 2000 outback? Were there different 5 speeds in different years (2000-20004) ? Will a forester 5 spd work? I just want to know what to look out for when looking for one.
P.S. Its a 2.5L
#5 ·
did you try the JDM importers
locally to LA they might have the best offerings?
______
I guess you could also get a short list off of local craigslists of part outs/ whole cars
like rust buckets driven from places like rural Colorado to UCLA / USC.
("California,
...where there is free edumacation, the ladies wear bikinis in winter, and the cars don't rust, "
....and the 2000-2004 rust buckets really stick out as something to toss when the head gaskets crap out).
@Kitesurfer805 (last online on 2/28/16)
bought a EJ251 off one out there around LA. when he could not find a good candidate for head gasket work locally.
(he had started with some EJ20 and then took it back, )
here is the nice pic thread on that
http://www.subaruoutback.org/forums/110-gen-2-2000-2004/165417-jdm-engine-swap.html#post2007658
here he is discussing his 2nd EJ251 project,
http://www.subaruoutback.org/forums...4362-2001-subaru-head-gasket-repair-rod-bearing-access-cap-r-r.html#post2381994
here he is discussing EJ253
http://www.subaruoutback.org/forums...rg/forums/109-gen-3-2005-2009/293161-2006-outback-2-5l-engine-rebuild-swap.html
here he is discussing JDM EJ20 with some poor guy in texas who actually put one in:
http://www.subaruoutback.org/forums...org/forums/110-gen-2-2000-2004/298265-engine-swap-01-outback-2.html#post3354209
I don't know if he ever posted a link or mentioned a name though.
________
and outside of you, the only other LA area member I know of is @Glennda5id
__________
however:
googling JDM importers port of long beach, LA, California should yield what you are looking for.
mtx outback had the same final drive as legacy ?
I know atx don't
#14 ·
Check out the PDF I attached in post #4 of this thread.
The trans code on my 2000 model 5 speed is TY754CACA which is a 4.111 FD, the local 5 speed for sale is TY754CBDA, which according to that chart is an 01-02 outback and has 3.9 FD.
How accurate this chart is I do not know.
#15 ·
USMB members may have more and better data carts,
( @grossgary is hanging there and has a real pension for such what can go into what swap....or have a source at hand or able to critique that chart.)
possibly on Legacy GT.com
or, Nabisco = Nasioc
_________
maybe your best bet maybe to just buy off Car-part.com yards/ warehouses (there are a few others out there like that too).
