This is probably a dumb idea but sometime next summer I will begin my attempt at turboing my 03 L.L. Bean. I have minimal knowledge on these cars and plan to use as much OEM subaru stuff as possible to make this happen.
Currently looking at using an 04 forester xt tmic, turbo, and a coolant reservoir . When I go to pull the parts from my local salvage I plan on also grabbing just about anything else connected to the turbo or intercooler that looks important. Currently working on tracking down a baja turbo hood as well for that tmic. I don't plan on running much more than 7lbs of boost, just enough to make it a little quicker while maintaining reliability. I'm happily accepting any recommendations and advice for this project and I do want to do my best to follow through.
I'm still in the part sourcing phase and will not start this properly until around March.
Update 11/24/2024-
05 Forester xt tmic, coolant expansion tank, Baja hood, and bpv have all been acquired. I'm going to attempt to use the TD04s internal wastegate but it'll entirely depend on how low I can get that turbo to boost. If I can't get it under 7psi I'll run the WRX map sensor as cardoc mentioned below since that doesn't appear to be a huge expense depending on the model and new vs used.
Update 11/24/2024-
