I finished the install of a Kicker 12" CompR 2-Ohm 500W RMS Sub-woofer Enclosure, with Kicker CXA600.1 600W RMS mono amp, 2-Channel LOC, and Kicker Remote Bass Control in my 2017 Outback 3.6R Touring. I have been looking around these threads and did not see one specific to Gen-5 Outbacks, especially 2016/2017 Outbacks with the Fujitsu TEN NAV HU and HK amp, with the level of detail needed to be able to feel comfortable hacking up my wiring harnesses. :|
Let me start by saying that I wanted to keep my car as stock as possible and not mess with replacing the Fujitsu TEN HU w/ NAV and HK amp with another aftermarket product. I really wanted to keep all the controls the same in the HU, allow the mediocre EQ settings to still control the car audio including the aftermarket sub I am installing to beef-up the wimpy sub in the rear-side panel. It's really non-existent as are the rear-door woofers! The front woofers and the three tweeters in the dash sound OK, but now that I have the sub thumping I am going to replace the tweeters and woofers next with something not requiring a tremendous amount of customization and allowing me to continue using the HK amp.
I have seen some other comments on these threads about the new Gen-5 Limited/Touring model HU wi/ NAV having line-outs instead of speaker outs from the HU to the HK amp. This is true as shown in Diagram 3: HU to HK AMP Pinouts where pins 7 and 8 are the line-outs feeding the HK amp.
Diagram 1: General Overview
Ok, this is really to show a high level view of what I did and where I placed the equipment.
Diagram 2: Wiring Taps and Pins
The is my equipment with contact points for each component diagrammed out. You can refer to Diagram 3 and Diagram 4 for specifics of the pinouts.
The amp socket pinout should be interpreted as if you are looking directly at the HK amp where the 24-pin (HK amp side) connector "i262" from the HU connects into the HK amp socket. The 24-pin HU plug should be interpreted as if you are looking at the end of the harness plug connector. The colors are correct and I can affirm pin 12 is the turn-on wire for the HK amp. I piggy-backed this for the Kicker amp remote turn-on.
Diagram 4: HK AMP to Speakers
The amp socket pinout should be interpreted as if you are looking directly at the HK amp where the 30-pin (HK amp side) connector "R316" from the HK amp routes out to all the speakers. The 30-pin plug connector should be interpreted as if you are looking at the end of the harness plug. The colors are correct and I can affirm all pins are true to the detailed fuctuion. I tapped the 2-Channel LOC (6-wires: ground, ground, L-, L+, R-, R+) as shown in Diagram 2 into the rear woofer speaker outs - pins 14/29 (Rear Left), 15/30 (Rear Right), 3 (Left Ground), 18 (Right Ground). The RCA outs fed the Kicker amp RCA input.
I was able to validate some of the diagrams from other posting, specifically the one on LegacyGT threads: URL soon since I am a noob poster here.
LegacyGT - chithead and svxdc had some great feedback and posts related to Gen-6 Legacy, but I was able to leverage for this post.
I hope these help some of you trying to do the same without completely modding the whole car ... I just needed a little BOOM! to make my commutes more enjoyable! I will post some photos soon ... next week or two of what things actually look like in the car and where you can route the +12V amp power through the firewall. Best of luck!
Photos soon ... I have to wear off my noob first.
