All warning lights just came on - lit up like a Xmas tree
1 reading
37K views 25 replies 13 participants last post by  Barbara Brownlee
I was driving this morning on a cleared two lane hardball - sunny day - clean windshield and out of nowhere every warning light came on. All the Eye Sight stuff, engine check, info stuff I never even knew existed. Drove it right over to Subaru - they plugged in the computer diagnostic handheld but the Service guy said he never saw the code before and would have to use the laptop diagnostic to see what was going on. Then he came back and wanted to know if I used a fuel additive which I told that I never have 87 only every time from Sheetz. So they gave me a loaner while they look into it.
Anyone run into anything like this.
EDIT: just got a call from Subaru - they have narrowed it down to one of two sensors.
#5 ·
Yes, lots of people have gotten something like this. "Christmas Tree" can result from any number of mostly trivial electronic glitches such as bad sensors, battery problems, etc., including intermittent ones. Eye-sight will shut down if virtually any of the electronic systems generate a flag from some failure mode or another. Other warnings may be consequent to the non-operation of some linked system or, as people say, may be a gratuitous means of capturing your attention. As in this case almost all the failures are false, but somewhere some one of hundreds of possible faults has been generated.
It took Subaru two years to chase down intermittent "Christmas Tree" in my car to a faulty original battery. None of the diagnostics detected by computer were an actual problem, but they spent what had to be thousands of dollars replacing engine control computers before they figured out that simply replacing the battery would do the trick, something a lot of people we now know would have done first off. Just a little bit too low voltage for a few milliseconds in some circuit can set a fault flag.
Yes that is true. The systems often depend on information or function from other systems to function. The issue is still there that the actual fault may not reside in any of the systems, such as my battery problem which generated fault codes that directed service to replace computers instead of replacing the battery, for which apparently there was no fault code to be generated. They also fault checked the wiring harness, another possible source for this sort of thing, but that was not the problem.
Happened on our 18 OB 3.6 11K miles last month while on vacation. They said it was an O2 sensor and I asked that paperwork be sent to me on what was done but haven't seen it yet. Running fine for 2K miles so far. She felt fine at the time.
Have to add that DeVoe Subaru in Naples Florida had a tech taking the car within 5 minutes of us walking in the door and problem diagnosed in less than an hour. We were treated like we had a new Bentley. BEST experience I've ever had at a Dealership.
#14 ·
Same here with Flow of Winston Salem - walked in and told them and the service guy had the handheld plugged in right away.
#15 ·
OK got the car back - it was diagnosed as: oxygen sensor slow response bank 1 sensor 2
Swapped rear 02 sensors between RH and LH converters and performed drive cycle - problem stayed on RH side converter. Took fuel sample (7% ethanol which is OK)
They replaced:
Exhaust Pipe AY Front
GSKT EXH PIPE F
GSKT EXHAUST JOINT OUTLET
RH catalytic converter
