Correct Axle Ratios check
1. Position vehicle on the ground.
2. Lift one side of the vehicle so that the tires are off the ground. Block the wheels on the other side of the vehicle as a safety precaution. If lifting the vehicle with a floor jack, place jack stands under the vehicle.
3. With a marking crayon, place a mark on the two raised tires at the 6 o’clock position.
4. Open the hood and disconnect the main wiring harness for the transmission or unplug the TCU. This will put the transmission in its Fail-Safe mode.
5. Place the transmission gear selector in Neutral.
6. Start the engine.
7. Manually rotate one of the raised tires through at least five rotations.
8. If both axle ratios are the same, the marks on the tire should be in the same positions as each other. If not, the axle ratios are different.
my question is this: On a 1998 OBW auto, for step 4. where is the harness connection point for the transmission or TCU for disconnecting?
thanks!
