I'm working on removing the passenger side axle from my 2000 OBW and i've met fierce resistance. I couldn't get the Ball Joint to come free from the Hub but did get it out of the Control Arm. So here's where I am:
Axle Nut Removed
Ball Joint Bolt (12mm) removed
Hub Assembly removed from control arm with Ball Joint still attached to Hub
Strut Bolts loosened
Axle shaft free from Transmission side (inside)
Three pound hammer to end of Axle gives no result.
Any experience or advice is much appreciated. -John
Axle Nut Removed
