Do you change the brake fluid on your Subie? My understanding is that this service is not really essential, unless the fluid gets contaminated. I use test strips once a year when I change my oil to check the brake and coolant fluid.
I'd call that going by faith. I'm going by what I learned as a mechanic, not faith, doubt or anything else.Plus I highly doubt your brake suddenly stops working because of "bad"fluid.
That is a very good point.It should be changed on some schedule.
One of the shortcomings of using test strips on the brake fluid is you are really only testing the fluid in the reservoir. The brake fluid is not circulated through the system like coolant or engine oil would be.
If you sample the fluid at the calipers too, that gives a better picture of fluid health.
DOT 5 fluid is also totally incompatible with DOT 3 or 4 brake fluids. DO NOT MIX THEM.... phase-separation of water is a problem with DOT 5 (silicone-based) fluids, as they have basically zero miscibility with water (very low to zero solubility).
