Okay, I'll try to comment to everyone helping here...
Ktiemann - yes, the XV picture looks the same.
Tishers - absolutely - that's why this is a safety issue Subaru should be addressing with their future Outbacks. They should be making their future vehicles improve, not digress.
Tmac - Thanks to you and others - yes, these straps look to be the best solution. I've popped my hood and inspected inside and out both front and rear. My plan is to bolt in the straps to empty holes in the steel (sheet metal) frame near the headlights. This certainly won't be as strong as a frame-anchor; however, should be plenty strong enough to hold boats when the straps are also caught under the latched hood. On the rear, I'll use the straps that look like their attached to a stiff plastic or rubber pipe just put under the latched hatch. Brucey & all - I noticed you've discussed various issues with others not having the straps anchored in good locations. Does my idea sound solid considering using the empty bolt-holes near the lights on either side of center near the headlights under the hood? I'd say it's the best option I've found so far...
Brucey - I believe whatever "baby-loops" you've mentioned on the previous generations were on the front bumper assembly which likely were plastic. What I had used for the 1998, 2001, 2003, and 2006 models was the welded 3/8" steel tow loops (okay somewhere between 6 and 10mm I can't remember without the vehicle in front of me) that were underneath the bumper assembly back a little further; but, still within easy reach. They were just to the inside of each fog light and made running a rope to them a real breeze once you got down on your knees enough to reach them. On the back of the vehicles (none of mine had trailer hitches - I still should get one) there was another loop of the same diameter steel that was no further back than it was on the front, right in the center and welded to the body. I had wonderful experiences of using both the front and back anchor points to winch other vehicles out of snowy ditches with no issues, so I know they were plenty strong enough for carrying boats. They had also been used to winch one or two of those Subaru's up onto flatbeds as they were the official tow-points on the Outback versions I had.
