DIY: Spark Plug Change 2.5, '13 and later
161K views 59 replies 39 participants last post by  Old Timer Shadetree
2.5l Engine Spark plug DIY
Vehicle: 2013 Outback (timing chain endgine)
Difficulty level: 2 out of five bloody knuckles.
My general takeaway: I can only use my own experience changing plugs on other cars as a reference: This job is way easier than doing spark plugs on a Camry V6 engine which can take hours. But the plugs/coils proximity to the inner frame makes it a fiddly job. To be honest, I was originally concerned that I would need to jack the engine up to clear the inner frame, but that is not the case.. With the right tools, it’s a breeze.
The annoying part is that the space is so tight that you cant just jam a spark plug socket, extension, and socket wrench into each hole all in one shot. You are constantly assembling/disassembling in order to feed the tools in/out of the tight space.
Here’s a good primer video with the basics of spark plug removal for cars with aluminum cylinder heads:
Tools: (From left to right)
• 3/8 socket wrench
• 14 mm Spark plug socket (note: you really want to use a spark plug socket that has the little rubber insert. Otherwise, a regular socket will undo the plugs, but will not extract them from the rather deep cylinder head. I did not have one in my tool set, so I removed the rubber insert from a 5/8 spark plug socket and stuffed it into a regular 14mmdeep socket.)
• 10mm socket
• 10-inch 3/8 straight socket extension (optional)
• 3-inch wobble extension (note: this may be the second-most important tool to have. Having the wobble head on the extension gives you more leeway to work around the edges of the frame. I tried doing one plug with a regular 4-inch straight extension, and it was very clumsy work).
• 1-inch 3/8 extension (optional)
• flat head screwdriver
• Dielectric grease (not pictured) Here on Amazon
• Iridium Spark Plugs (not pictured) NGK Silver Iridium here.
NOTE: I could not find my little 1/4 socket wrench at the time of this job. If I did have it available, I would have used it and a 2-inch extension for all of the 10mm bolts and nuts. It would have been much easier that way.
Replacing the Spark Plugs
1. Disconnect wires to each of the coil packs.
2. Use 10mm socket to remove the only bolt on each coil pack. (optional: Once you break the bolt loose, disconnect the wrench and use the 1-inch extension on the 10mm socket to run the bolt out by hand. It’s way faster).
3. Pull each coil pack off. It may take some wiggling as you back the coil off the spark plug. Take your time. Those things are expensive to replace.
4. Spark plug removal:
_____a. Slide the spark plug socket (alone) into the cylinder head.
_____b. Slide the 3-inch wobble extension into the spark plug socket.
_____c. Make sure the socket is seated on the spark plug.
_____d. Attach socket wrench, and gently loosen the spark plugs. Remove the socket wrench from the extension when you start bumping into the inner frame.
5. Put a dab of anti-seize grease on the treads of the new plugs.
6. Put a dab of dielectric grease inside the rubber hole of the spark plug socket, and then . (The grease will help the socket release the spark plug once everything is tightened down. Otherwise, the socket might stay in the cylinder head when you try to pull it out. Ask me how I know this!)
7. Thread the spark plugs in by hand. Once they are hand tight, use the socket wrench to give the plug another ¼ turn.
8. Reinstall the coil packs
9. Reconnect coil wires
10. Reinstall 10 mm bolt to hold coil packs in place. Tighten them to “snug” (translation: don’t go crazy).
General Tips:
1. I found it very difficult to extract the socket/extension from the driver’s side rearward spark plug hole, because I kept bumping into an aluminum A/C line that’s attached to the inner frame. I solved this by gently removing the AC line from its plastic clip and moving it about an extra ½ inch out of the way. Make sure you reconnect the aluminum line when you are done.
2. The passenger side plugs require you to remove the air intake. Here are the steps.
_____a. Disconnect the wire to the MAF sensor located near the air filter housing.
_____b. Use flathead screwdriver to loosen the ring clamp on the air inlet tube where it connects to the air filter housing and the throttlbody.
_____c. Pry up the plastic fastener that holds the air inlet tube to the throttlebody. Remove air inlet tube, and set it aside.
_____d. Pry loose the fasteners that hold the air intake on the front radiator support. Disconnect the air intake from the air filter housing.
_____e. Open the air filter housing, and loosen the 10mm nut that’s hiding in the upper edge (secures it to upper radiator support).
_____f. Use 10 mm socket and 10-inch extension to remove the bolt that holds the airfilter housing to the inner frame.
_____g. Move the air filter housing out of the way, to gain more access to the front spark plug coil.
_____h. Put it all back when you’re done AND BE SURE TO PLUG THE WIRES BACK INTO THE MAF WHEN YOU”RE DONE.
While You’re in There:
Here are some other maintenance jobs that you can plan on doing during this job.
1. Clean MAF Sensor: https://www.subaruoutback.org/forum...rself-illustrated-guides/55657-diy-gen-4-maf-mass-air-flow-sensor-cleaning.html
2. Clean Throttlebody
3. Replace Air Filter
Thanks for sharing your experience. It was nice to see that you rated this only 2 out of 5 for difficulty. As one who prefers to do my own maintenance on my cars, I was a little worried about the horror stories I have heard about changing plugs on a Subaru.
The special techniques, such as the wobble extension, are good to know. I can see how that will help.
#5 ·
Thanks for the write-up, any pictures would be appreciated as well, but you've done a really complete job of explaining the process and listing the equipment needed.
Will be doing this on my 2011 here soon, I am sure the procedure is fairly similar to your updated motor.
Thanks again!
Thanks, Hans.
Excellent write-up, including gotchas/facepalm situations. As you have (and with any DIY), the tool list is important so you’re all set before you even begin disassy.
Looking forward to your pics.
What do you mean ‘wobble extension’, (that’s a 3/8 x 3/8 u-joint + 4” ext)?
Here’s another for your toolbox: GearWrench 80546 5/8 x 6 swivel sparkplug socket.
Great question. Here's the kit that I own.
Craftsman 4pc Wobble Extension Bar Set 3/8 Inch Drive - Tools - Ratchets & Sockets - Socket Accessories
I am attaching a cloesup of that wobble extension. You will notice that the tip of the extension has some different angles compared a normal extension. This allows the shaft to wobble around a few degrees and still hold onto the socket. Its range of motion is less extreme than a U-joint extension, which can tend to bind up.
NOTE: I just realized that I had the size of the extensions wrong. It was actually a 3-inch extension, not a 4-inch one. I corrected that above.
#8 · (Edited)
OP says "The annoying part is that the space is so tight that you cant just jam a spark plug socket, extension, and socket wrench into each hole all in one shot. You are constantly assembling/disassembling in order to feed the tools in/out of the tight space."
I did not find this to be true on my 2012. The passenger side has plenty of room with the airbox disassembled. The drivers side rear plug - there is a void above the fender and below the fuse box that allows for the socket/extension to back into the void and go directly into the rear plug hole. Drivers side front plug - there is a gap behind the battery that allows the tools to back into the gap and go directly into the front plug hole.
Based on this thread, I was worried about the difficulty of this job, but it was easier than all the front-wheel drive V6 cars I've worked on. Replacing the plugs on my 2012 OB this past weekend with 69k, the plugs still looked pretty good. Using two 3" extensions and the plug socket, the total length was exactly 7" and I had no issues feeding everything in and out as one piece for all four plugs.
I used:
3/8 drive 10mm socket
3/8 drive spark plug socket
3/8 drive 3" extension x2
3/8 drive ratchet
tubing
Never changed plugs before? Fear not! The H4 engine in an Outback and this thread is the best place to start. You can do it!
Some additional advice:
On the new plug - (EDIT - NGK plugs are plated so they don't require anti-sieze grease. If you choose to use anti-sieze, torque your plugs carefully!) I add a small dab of anti-sieze grease to the threads and work into the threads with a paper towel. Add dielectric grease on the terminal end. Use a piece of tubing (fuel, brake fluid, etc, I used a drinking straw) and slip over the terminal. Use the tubing to lower the new plug into the seat and tighten by hand until the tubing spins on the terminal. If the tubing slips right away, you may be cross-threaded, start over. If you get about half to one full turn until the tubing slips, you're good. Do a couple plugs and you will know the right feel. Use the socket/extensions and continue tightening by hand, this should go relatively smoothly, if not, back everything out and start over. Again, it should feel right. Finally, finish tightening with a torque wrench where possible or normal ratchet where space is limited just don't over torque!
Make sure the insert inside the plug socket is clean and dry to remove the old plug. This will make sure the old plug holds in the socket and you can pull it out without the plug falling back in the engine. Put some dielectric grease on the rubber insert before tightening the new plug. This allows the insert to slip off the terminal when you are done and not get stuck on the new spark plug after you pull the socket out. You could even remove the rubber insert from the socket for installation, its now unnecessary because you already got the plug started with the tubing.
On the new plug - add a small dab of anti-sieze grease to the threads and work into the threads with a paper towel.
I have always been putting anti seize on the plugs too but will not do it with NGK plugs (i.e. the OEM plugs) going forward. Here's why:
NGK spark plugs feature what is known as Trivalent plating. This silver or chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. This coating also acts as a release agent during spark plug removal.
Source: http://www.ngksparkplugs.com/pdf/dyk_5points.pdf
I've always been a bit leery about overtorquing spark plugs with anti seize applied, so knowing that I don't need to use anti seize is good.
I love anti seize though and put it on just about anything else that otherwise tend to seize from rust, heat or corrosion.
Interesting about the coating, too bad NGK doesn't make this more well known. I also found this: "For spark plugs with special metal plating: do not use anti-seize on the initial installation. If a spark plug with special metal plating is removed and re-installed, only then should anti-seize be used prior to re-installation"
So even if I un-did my "mistake" and cleaned the threads, I'd then have to use anti-sieze, so I really should leave well enough alone. Wiping the threads with a paper towel before installation also means there is actually very little anti-sieze grease on them anyway. Lets not forget the concern here is the proper torque of the plug itself, and I'm ok with the torque I used.
But, good to know going forward, thank you OBDad.
#11 ·
Just replaced my spark plugs uesterday in my 2011 Subaru Outback 4 cylinder. Replaced the factory plugs with NGK BKR6EIX-11. I found it was an easy job, taking a total of less than two hours. Here is a You Tube video I watched that was also helpful in identifying some of the potential challenges and shortcuts. https://www.youtube.com/watch?v=mCF5n5mDyJo If you have any mechanical ability, it is not too difficult a job and can be done relatively easily. I did not need any of the tubing or wobbly extensions. Just be careful installing the new plugs - you don't want to cross-thread them in an aluminum head!
The OP used a 3" wobble extension and another poster used two, which do you need? Also, what is the size of the spark plug socket? 14mm doesn't appear to be a standard size for a plug socket, at least as far as CRAFTSMAN is concerned.
I have a 2014 2.5 that will need a plug change in a month or so that I plan on tackling.
Spark plug gap is many times on the under hood federal emissions decal. I believe it is around .44 thousandths.
It is always a good idea to check the gap before installing new plugs.
#22 ·
I literally just did this.
The post is great except for a few pieces.
1: Because of the needing to assemble and disassemble the sockets in the spark plug hole it was a bit more difficult than your rating implies.
2. The gap between the driver's side rear spark plug hole and the frame is SUPER TIGHT. I found the 3 inch wobble extension to be a little long and my one inch (using a 1/4 drive socket) to be a little short. Next time I am buying a 2 inch extension. I also had to have help disassembling the sockets and extensions when removing this spark plug. My wife held the extension with a pair of vice grips and I used a long handle screwdriver, from under the fender, to knock the socket off.
3. A telescoping magnet helped me a lot with pulling out sockets and plugs with out dropping them.
#23 ·
Mirrors my experience doing mine yesterday. On that driver's side rear plug I actually thought I might have to use my reciprocating saw with a hacksaw blade to cut my stuck-in-place 3" extension in half to remove it before a lucky contortion freed it.
The driver's side took me 3 times longer than the passenger side. Glad it's over for another 60k miles. And the cuts and abrasions on my hands and arms are already starting to heal.:laugh:
Thank heavens the plug terminals were magnetic. Helped me a lot.
On a side note the OEM plugs I removed (63k) looked pretty good gapwise, though they were pretty grungy.
I really didn't expect much benefit, but that little stutter sensation in engine speed/sound when coming to a stop is gone, so guess there is something to this 60K plug change after all. And I can't swear to it, but I think she starts a little easier, though could just be the old placebo effect.
I just completed this job over the weekend on the FB-25 2.5, and wanted to add a few points -
  • The driver side rear plug is a real bear, as discussed previously (four bloody knuckles). The other three plugs are easy in comparison (two bloody knuckles).
  • I did not have a 14mm socket with a rubber insert, and my 5/8 insert was too big for the 14mm socket. I was able to remove the old plugs from the engine cavities using my fingers, once I had completely backed the plugs out of the threads. If you have long fingers, this is a viable option.
  • I switched to 1/4" drive sockets, extensions, and ratchets for the driver side rear plug, and that helped quite a bit. I found the smaller size drive to be a bit more nimble that 3/8", so would suggest trying this route if you have a 14mm deep socket in 1/4".
  • Use a narrow and long slotted screwdriver to free the socket from the extension when it is inside the engine cavity.
  • The original write-up is spot-on: you just have to use different lengths of extensions to make this work. I tried using a wobble, but it did not help much.
  • The original plugs looked pretty good at 60,xxx miles, with some moderate carbon build-up. I would guess they could have gone another 15,000 miles without issue.
Bottom line - this job is doable without jacking up the engine, but just barely. I really found myself in a pickle with the driver side rear, when I could not press the release button on my ratchet to release the socket extension. It eventually came free, but I briefly thought I would have to jack the engine to make it work. The spark plug change on my 1.8 TSI Golf will be a breeze compared to this:smile2:
Good luck!
#26 ·
Updated for Gen5 spark plugs
I believe that the Gen5 Outback is a little harder than the Gen4. Mostly because I can't recall any issues changing them in my 4?
I changed the plugs over the weekend and it took me @3 hours for the job. And my hands are all busted up.
The main problem is the removal of the battery box. Subaru's tech site says the battery needs to be removed but I am assuming that the box needs to go as well as there are two bolt heads directly across from the forward-drivers side ignition coil and you need all the space you can get. Those two bolts are the hardest to get as there is no room for a ratchet so I was using a 9/16 crescent wrench to break it then using my fingers to spin the bolt. Very time consuming. If you have one of those ratchet wrenches they might work depending on how much space you need to swing.
Once the battery box was off, the ignition coils need to be disconnected. Trying to depress the spring while pushing the connection off was difficult in the tight space as getting enough leverage was tough.
Once those are done the coils and plugs themselves are easy(ish) as all you really need are a wobble extension and a magnet. Don't use a 3" extension on the spark plug socket on the rear drivers side as you will have issues separating them to get them out!
Passenger side is a piece of cake. Remove the air cleaner and everything is easy access.
One thing to note: after the battery has been out the "autodown" feature on the windows will not work. WTF? They need to be initialized. Just put the window down a bit then back up and hold the button "up" for a few extra seconds. Needs to be done for both windows.
#44 ·
hi,
it's time to do 60k ml service for my OB
I watched
where engine was jacked for 1-1 1/2 " to has more access space.
should I follow with jack up engine?
or is it Ok without?
I ordered OEM from amazon https://www.amazon.com/gp/product/B009MVNSGQ do I need anti-seize for those?
thanks
I have what appears to be a front engine mount on my 2014. This video does not mention it. What am I missing?
#31 ·
I got the spark plugs from amazon and checked the gap
3 out 4 has 0.030 and 1 has 0.035
should I adjust to 0.044 ?
is it normal to get spark plugs that are not factory to 0.044?
thanks
The plugs are intended for many applications, not just yours. While many state they are pre-gapped to some specification, they should always be checked. And they should definitely be set according to the label in the engine compartment.
#32 ·
It's not needed for a Gen 3 H4 NA.
If you managed the 2014 without doing this, I would avoid doing it on the 2016. There are tricks to changing plugs efficiently and you learn them over time; besides that, it's not that often that you have to do the job. Used to be every 30k miles or so with leaded fuel.
Thank you, Hans! I just did spark plugs replacement on my 2013 OB 2.5i for 60k maintenance. As everyone pointed out, the driver side rear one is the most challenging due to the tight space. It took a lot of work to extract that spark plug out. I have a 3" wobble extension and a 2.5" spark plug socket. Because the assembly of about 5.5" will bump to the frame, I have to disassemble the wobble extension while 'holding' the spark plug socket in place. It's highly likely the socket and spark plug would fall back. So I need to insert the extension again... Really wish I have a bendable telescoping magnet on hand.
#34 ·
2016 Plug Change (62k miles)
I started this yesterday, beginning with the drivers side...and ended with the drivers side! I have large hands so removing the battery bracket was a necessity...and also very difficult. The two inside bolts (facing the engine) were very difficult for me to get loose. Plus neither of which would free spin with my fingertips...so just a fraction of a turn using a wrench. It was horrible. I never was able to get the rear wiring connector disconnected from the coil. The front had enough slack to easily work with. The plugs looked ok, well within heat range but there was some wear and increased gap. The new plugs were installed (drivers side only) and everything put back together. This morning I will tackle the easier, passenger side.
Once that is done I will be doing a drain and fill on both front and rear differentials. The CVT was a drain and fill on Monday. All went well.
The plugs on our 2011 OB were a LOT easier to change than this 2016. It was still tight, but easily doable. At 120K I will be "paying the man" to do the next spark plug change on the 2016!
Thanks to all for the great info that is provided within the pages of this forum!
