My new to me 2006 Outback XT's drivers door worked fine till today. I opened the door with the key to just lay an ice scraper inside and then re-locked it with the key. About two hours later the drivers door will not unlock at all.
I tried the fob. All other doors work fine.
I tried the key in the lock. I can lock it but it will not un-lock with the key.
I tried to reach in and unlock it from the inside. The manual lever does not rotate like the right side.
It will not open even with the door handle.
All other doors will lock and unlock fine and the alarm will set.
I had to go pick up my wife so I had to crawl into the drivers seat and go get her, then crawl back out.
It has not been icy but I am just getting set up for the coming times, it was above 40F most of the day.
