How to change a Subaru Key or Fob battery. No tools required!
7 reading
431K views 4 replies 4 participants last post by  Brucey
#1 · (Edited by Moderator)
You'll have to replace those batteries sometime and not everyone is mechanically inclined.
Instead of a trip to the garage or shop, you can pick up a battery at your local convenience or grocery store quickly and replace it yourself.
There is a small trick to get the fob open and that is to remove the glove box key by pushing the silver button and use it to push open a small slot that is revealed.
From there you can remove the battery and replace it.
Easy peasy! If you need the battery you can grab a 5-pack of the required 2032 style battery here for less than I paid for my single battery at the store.
If you have the key it's still pretty easy. You'll need a flathead screwdriver, steak knife, or the key fob key (;
Just push it into the small slot and break it open. It all clicks apart and clicks back into place.
You'll need a 1620-style watch battery. Here is a 5-pack for $5 shipped.
Hope this helps someone!
