Hi!
I need to change passenger side valve cover gasket of my 2008 Base model Outback. FSM calls removal of fuel injectors. Now, there is a method to lift the engine (and transmission together?) by about a couple of inches and remove the valve cover without removing fuel injectors. I wonder if anyone has performed valve cover gasket replacement this way on a Gen 3. If so, can someone provide me advise and guidance.
Thank you.
Thank you.
