I disconnected the battery on my 2010 OB at the weekend to install a Media Hub. Now the driver's window no longer has auto-down/up. I know there's a magic trick to reset this, but I can't find it anywhere. Does anyone know the secret?
Thanks man, that is an interesting and simple little fix.Initialization of power window
If the vehicle’s battery is disconnected due
to situations such as battery or fuse
replacement, the following functions are
deactivated.
. One-touch auto up/down function
. Anti-entrapment function
Initialize the power window in the following
procedure to reactivate such functions.
1. Close the driver’s door.
2. Turn the ignition switch to the “ON”
position.
3. Open the driver’s side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely.
Im having this exact problem. My battery died on me once and turned off the auto feature (which was already going in 1 inch increments) and the window went up and down without problem. I tried the "fix" to re-enable the auto touch feature but it made it go in 1 inch increments againso I tried this half open window method and it didn't work. the window goes down fine, but goes up only 1 inch with each pull. any thoughts?
I just got in the car started it and rolled the window down and held the switch for 1 second and then rolled the window up and held the switch for another second.. Window worksInitialization of power window
deactivated.
position.
switch.
The "auto up reset" function described in the above posts and in your manual should work.I just came back from work. I drive a 2012 Impreza 2.0. I never had a problem with my driver side window until tonight while trying to open my frozen window. Now the window goes up inch by inch when I close the window. Anyone now how to fix that problem?
The auto up/down on the driver's side window in my 2013 Subaru Legacy stopped working. The window went down if you held the switch down. But going up, it only went 2 inches at a time. The fix was: run the window down and then up 2 inches at a time. When the last one closed the window, continue holding the switch in the up position for at least 5 seconds. That fixed the auto up/down feature.My driver's side auto-up/down feature stopped working for some reason. Found this video and was a quick fix.
