I have replaced my four door speakers (I have no dash speakers installed) with fairly nice JBL speakers and while the sound is undoubtedly cleaner the "bass problem" still exists. In fact, my front door speakers are now 6X9 instead of the 6 inch stock. The 6X9 can easily produce more bass, so in a way the "bass problem" is even worse now (although the sound is clean now, not muddy). I am definitely not a fan of rap; sometimes my non-rap songs result in that crazy deep booming vibration that overwhelms the senses.
The Premium's stock "equalizer" can be used to "reduce" the amount of bass, but at the lower frequencies the adjustment ranges from "lots of bass" to "ridiculous amounts of bass."
In my past experience, reducing the bass to full minimum on an equalizer would cut the bass out, ideally to zero. This is not the behavior of the EQ in the Premium's Fujitsu system.
Certain songs sound good. Others have insanely high bass levels, even on songs that do not exhibit this when played at home or in another car. I set one of the custom EQ buttons to kill the first two frequencies entirely and this is useful for some songs, but if the song has someone playing a bass guitar at a normal level, be prepared for awful levels of bass. There is apparently no way to get rid of it. I simply do not understand how the development team ended up with this system configuration. My only guess is that they did not fully put it through it's paces or perhaps they tested it with songs containing very little base (for which the system might sound quite good).
I am considering installing an aftermarket Alpine amp after the HU but I am concerned that the excessive bass is hard wired into the audio processing and that this will simply be passed to the Alpine amp and the problem will remain. I could try taking advantage of the Alpine amp's high-pass filter to cut out some of the insane bass but this is not the intended role of these filters in the absence of a dedicated sub-woofer.
I am not certain if the problem can be addressed in Fujitsu's firmware or not. It may be that the bass problem falls out of the circuit design and that the bass reduction provided by the EQ is at the edge of it's adjustment range.
Or perhaps a firmware update could fix it. If the Limited's more "limited" adjustment options (bass-mid-treble) successfully kills the bass down to a normal level then I suppose there is some hope. The two units (Premium and Limited) have much in common. The head units share a wire pin-out diagram (posted on another thread) and appear essentially the same. On the HK system the head unit feeds a separate HK amp with the front channel outputs only, while the Premium's takes advantage of an internal four-channel (lower powered) amp.
My suspicion is that if the firmware made it to production when scrutiny is high, then it's importance to Fujitsu will diminish going forward in time. Subaru would have more clout with Fujitsu than individual users, but I am not sure Subaru really cares. When I made comments to my dealer about the poor sounding audio system, I basically received a blank stare and a shrug.
If anyone adds an aftermarket amp (such as the KTP-445U) to the Premium system then I would be very interested if the bass problem is mitigated.
