Are you running a real-time engine oil pressure gauge? If so, where is it connected, and, what psi readings do you have. for example, when cold and fully warmed-up, and at idle rpm, when driving at 1500 rpm, and 2500 rpm?
I'm off on a tangent again, trying to confirm the usual working pressure for the VVL (variable intake valve lift) system. (The tangent is related to failing/leaking switches (http://www.subaruoutback.org/forums...blems-maintenance/49468-variable-valve-lift-oil-pressure-switch-resistance.html) and codes P0026 and P0028.)
I understand that the VVL is disabled until the oil reaches a moderate temperature. Also, based on my logging of related data, I'm reasonably confident the VVL doesn't switch to "hi" lift until engine is around 1600 rpm with the car driving and some load on the engine (i.e., not in neutral).
The VVL system has an oil pressure sensor switch on each head that indicates when the system is in high mode by monitoring the oil pressure to the camshaft from the VVL duty solenoid valve. My understanding of the VVL mechanism itself suggests that the oil pressure would have to be fairly high to engage the intake valve cam follower locking pins. Take this a bit further and I believe that the oil pressure switches are calibrated to change state (off/on) at a similarly high pressure. (Contrast that to the engine oil pressure switch which works at 2-4 psi!)
The engine oil pump bypass is around 85 psi. But what's the system normal operating pressure under conditions where the VVL would switch to high mode?
