Any body has a preference, pros, cons?
Do you have any evidence to back that outrageous 99% claim?Always use OEM, or WIX. Nothing else has a strong enough bypass valve for Subaru. Other filters spend 99% of the time in bypass mode due to higher oil pressure in Subaru motors and they do not work because a filter can't... Filter.... If oil doesn't go through it.
I use WIX.The bypass argument rears its ugly head once more...
I challenge anyone who pushes the higher bypass setting to a hard set of data supporting the need and if there is one,
Thanks for all the replies guys......
Im about to do an oil change and came across this video.....
Which it may or may not support the oil filter you are using....
Interesting to say the least.....
https://youtu.be/iTNJLEV8CG8
@Rub when you say "M1" are you referencing "Mobil 1" ?
BTW... I checked with my local stealership and the oil filter was about $8.00
How much time does Subaru think is acceptable in bypass mode? What factors are you relying on when you say, "more time than it should"?Not outrageous at all. It's basic physics. Subaru specs higher bypass valve because boxer engines run higher oil pressure than most engines. The oil filter spec'd to fit several vehicles at your big box store will physically fit, but does not have the same heavy spring resulting in the filter spending more time than it should in bypass mode. But, it's your engine so do what you want.
Sent from my ONEPLUS A5000 using Tapatalk
