Is there an easier way to make the rear 12v outlet constant on instead of running a wire from the battery? Like is there a locaiton close I can tap into? Need 10a or so capability for my water pump, (fridge is only 5 amp)
A good majority of cars come with optional towing packages, and as such, will have a convenient harness connection somewhere in the rear of the vehicle for installing a trailer 'tee' harness. Some trailer connections have an optional electric trailer brake connection as well. To my recollection, the electric brake wire is a constant 12V supply, but I'm not sure if your OB has the equipped option. Might be something to investigate.Didn't know if anyone knew a hot wire back there to tap into that would work.
Yeah, these numbers do not apply to the Gen 5, and I've already suggested this (except I tapped a different circuit)....Fuse 8 and fuse 13 are the correct connections for a Gen 4. I'm not sure on other generations...
It only takes a few minutes to read this thread and find that I have already posted exactly what you're looking for.BHOPKINS:
any way you can post pics?
thanks!
LOL I wish I could do thatAnd when it comes time to sell it off, just unplug everything and nobody will ever know you where there...
