Go to Mr. Subaru YouTube:
The best advice I can give you is to buy the Ko-Kem thin walled Sparkplug socket .
This is the 14mm used for 2.5L. The 6 boxer uses a 16mm socket. Believe me when I say it’s worth the money. I’m old and the job took me 3 hrs - 1 hr on left side….2 hrs for right side. This boxer motor has very tight clearances….and the Right Rear #4 for 2.5L was a royal PITA to get out and harder to install cap. I was fiddling around with the cap and thin wiring until Presto! stumbled upon just the only way to rotate the sparkplug cap & insert boot.
I used both 3/8” and 1/4” ratchets & extensions of several short lengths (1/2” and 1”) along with flex & wobble sockets.
FWIW the sparkplugs looked great at 80k. I used factory OEM and ordered from Rock Auto the specified NGK. And seeing how hard it was….I’m going another 80k for next replacement. By then I’ll be too old to do this 😀!
Some Hints: Dielectric grease & AntiSeize.
1) the Sparkplug boot was almost impossible to pull out - I was afraid that the boot would be damaged. When I reinstalled the Sparkplug boot, I used a Q-tip to apply a very thin coating of Dielectric grease in boot to help next scheduled Sparkplup replacement (@ 160k).
2) Anti-seize on Sparkplug threads - this “Tip” is controversial but I’ve worked on Motorcycles and cars for many years.
I used a very light coat of anti seize by using clean toothbrush to “paint” (very THIN coat) all but last 4 threads closest to Sparkplug firing tip). That makes it easier to thread in carefully with “feel”. I use my 50 yrs experience to tighten by “feel”. You have to carefully tighten….feel wrench bottom …a 1/4th extra turn to seat / compress Sparkplug washer.
Take your time. It’s a hard job but with patience it’s doable. Do not rush! I’ve done this on daughter in law’s 2014 Forester with 2.5L several years ago. It wasn’t that hard … maybe I was younger then? 🤪
I do not recommend this for Inexperienced home mechanics. It also helps to be young - I’ve got some arthritis. Good luck 👍!
