Torque Converter Lock Up Clutch 2012 CVT
11K views 7 replies 6 participants last post by  Fibber2
Hi guys,
I posed this question on the thread concerning this issue, but seeing I'm im Oz I was wondering if its an issue here enough and aby success with Subaru Australia. I'm on a lease so have to fork out a few extra payments if they won't contribute, once labour is added. Sorry if the double posting is a no no.
" My 2012 Aussie 2.5i CVT Outback, torque converter fail at about 117,000. Told them about shudders at service, no fault found. 500 metres from service centre it stalled in similar circumstances and a few times since. Finally diagnosed as torque converter, lock up clutch.
Just out of warranty, extended warranty invalid as I bought through dealer not owner ( could've paid $110 for ownership change and repair!?)
Now with a quote for AUD$1800 (!) for parts alone I am waiting on Subaru Australia to come to the party.
How can design a poorly performing part that is a global problem demonstrated by the tecnical notice and then make the customer wear the cost?
All you need is a stall in the middle of a busy intersection or a rail line and you are cactus.
Anyone had success with Subaru Australia?"
My wife's 2010 Outback has the same problem. It started shuddering when stopping. Told them at Subaru when getting serviced and they took it for a drive and confirmed it was a torque converter. They said they will get back to me about fixing but never did. The car has done 130000kms. What would the cost be to replace including labour through Subaru?
Subaru at Crossroads Glendale just advised me that it will cost $4500 with the oil alone costing $500. Sounds like I'm getting taken for a ride. Anyone have any suggestions for a mechanic that can do it cheaper as I am selling the car. I'm on the Central Coast NSW. Thanks in advance.
#5 ·
So far what we know is that Subaru publically stated that a washer type part that is involved in the pressure release of the torque converter gets worn and eventually fails to release pressure. The effect is a stall. Same idea as if you forgot to press in the clutch as you come to a stop.
My guess is that the material this washer was made of was the wrong spec metal and wears too easily fouling up the pressure release process.
So a couple of things to keep in mind
#1 Subaru publically noted this was an issue
#2 Subaru probably has a supplier agreement on parts cost for replacing the faulty part
#3 The labor and repair is similar to a clutch job except its only one part they are replacing vs worn bearings, plates and clutch..
This all translates to the dealer repair should not be without Mother Subaru assistance $500 or more credit along with a low part cost for the replacement part. If a clutch job is $1000 dealer job this failed Tourque converter job shouldnt cost an owner more than $700 at the most.
$4500! Your dealer should be reported to the states attorneys office for scamming customers on trumped up fees and false charges.
Updates
Did anyone get updates from this?
I'm in Brisbane with an Outback 2011 with the same problem.
Took to Subaru and got quoted $3950 to replace torque converter.
In USA Subaru has recall 1.5M vehicles due to the same issue as this is a serious safety issue.
I have tried to escalate this with Subaru but no luck just yet. I'd appreciate if you guys could provide your updates.
