Wilderness Custom Trunk panel Storage
6.1K views 14 replies 11 participants last post by  HeadOffice
I just purchased my Outback Wilderness at the beginning of the month I love it and I am dialing in on the things that I think would be better for my lifestyle.
One thing I saw in previous releases/trims was storage compartments under the trunk panels. I wish this was a feature of the wilderness but since it’s not I made my own.
I utilized the original foam to maintain the proper spacing and to register the trunk panels
Into place.
First step was a initial fitting with cardboard cut to the size of the original foam. After I added material to fill the difference. Once I had a good fit I went ahead and cut the template out of Hard board.
Next I stuck the fabric too the hardboard panels with a spray glue I had laying around. I chose to use headliner from Joann’s fabrics. afterwards I realized I should have used wool or felt something that Velcro grabs to better than headliner.
Once the fabric was all glued into place and holding I fit up the cut foam sections to the panels and hot glued the foam with a high temp automotive glue.
That was pretty much it they were ready I’m still going to clean up the cuts make it look more professional but that’s for another time I was cooking out there in the sun this weekend.
Example of the space I was able to utilize. Now I can store nearly all the contents of this roadside safety kit in this space.
It wasn’t a bad project and pretty cheap I ended up buying way too much material so now I’m thinking I could have spent $20 on materials. I wasn’t sure what I was going to use that space for but I was really hating how bulky that road side kit was.
I plan on using a hitch tire carrier on my OBW as I want to carry a spare to match the A/T tires and wheels and get some inside storage space for tools, compressor, etc. so this looks pretty cool. Thanks for posting it.
