I've got a 2024 Crosstrek 2.5L on order and have just seen in the manual that Subaru is now calling for 0W-16 oil.
My understanding is that the 2.5L has been slightly revised and now produces a whopping 2 whole extra ft•lb of torque. Do you think there have been changes that necessitate 0W-16? The manual says that 0W-20 can be used to top off if replenishment is needed, but should be changed back to 0W-16 at next oil change.
I know 0W-16 is thinner than the called for 0W-20 in our Outbacks and so should provided better cold weather warm up and fuel efficiency, but at the cost of high temperature protection and, well, cost.
My past experience has led me to take the position that manufacture recommended oil change intervals should be considered a maximum limit rather than a safe target.
I think the notion that clean oil (that meets the latest specifications) is going to perform and protect better than dirty oil, even if that dirty oil is an advanced formula that can outlast other brands.
In my OBW I am changing the oil (and filter) every 5000km using Costco's Kirkland brand oil.
My thinking is that the interval is overkill, but the oil is cheap (and at a consistent price) and still meets the latest specifications. It'll never be at risk of degrading too much and being so clean might reduce carbon deposits/sludge.
While I'm not specifically against using 0W-16 in the Crosstrek, my Costco here in Canada doesn't carry 0W-16. In fact there is very little 0W-16 available at local auto parts stores and they're easily x2 the price.
Given that the engine probably hasn't changed all that much, and the requirement to use 0W-16 is most likely related to their published fuel economy, do you think it's fine to stick with 0W-20? Yes, I know that warranty denial is a possibility since it's not what the manual says.
I know there are lots of knowledgeable people in here, I'd love you hear your thoughts.
