How to Install Guide: LP Adventure Canister Filter Bypass
39K views 39 replies 19 participants last post by  Visionprdx
#1 · (Edited)
This is a how to video, how to guide, and review for the LP Adventure canister filter bypass.
Video version:
Text version:
The purpose of the bypass is to avoid damaging the fuel canister when traversing deep water in a 2015-2019 Subaru Outback.
After reading multiple people having the same issue with water, it seemed like a worthy investment.
Usually people would drive through deep water or foods or even heavy puddles and the car would throw a P1449 error code. This should help fix it by bypassing the filter and saving the owner $1800+.
Tools needed:
Flat head screw driver, Phillips head screwdriver, 10mm socket and socket wrench. A clip removal tool would be nice but isn't necessary.
The install goes like this:
Jack the car up, take the driver rear wheel off, put it on jack stands.
Start removing the rear fender liner. It's held on entirely with rivet clips/pop rivets/automotive fasteners. To remove them just use a flat head screwdriver to pull the center pin out to release them then pull the entire thing out either with a flat head screwdriver. I have a removal tool that wraps around the entire collar and helps prevent damage to them.
I think you could likely do this without completely removing the fender liner and just bending it out of the way but I chose to completely remove it for the sake of the video. The goal is to get to the fuel canister located behind/above the fender liner.
With the liner out of the way, disconnect the line coming from the rear axle with the red clip. I had a little trouble with the clip as it kept wanting to snap itself back in place. Just took a few tries nothing too hard.
With the line disconnected, insert the plug and reinstall the clip thus locking it in place. Take the zip tie and tie the piece down so it's not rattling against things causing noise.
Take the bypass and install it where you just removed the breather line. It just installs using hose clamps.
Big note here: I had to disassemble the bypass completely and reverse the elbow that had been sealed as the wrong end was cut. It took me ten minutes to figure this out as I expected a part that was supposed to be bolt on to not require modification.
With the bypass now installed remove the 10mm nut towards the front, install the supplied clamp, and reinstall the nut to hold it in place.
You're done! Super easy.
Reinstall the fender using the clips, reinstall the wheel, get it off the jack stand and enjoy your new submarine.
Some final thoughts on the LP Adventure Canister Filter Bypass:
With shipping mine ended up being $66 delivered.
I have sourced some parts here:
K&N Filter
90 degree elbow (will have to be cut to fit)
3/4 Hose. It's actually too much but I couldn't find a smaller quantity.
Clamp (10 pack probably better to source locally as you only need one)
hose clamps (need 4 this includes 5)
I think the more handy types will be able to source everything but the K&N breather locally and for cheaper.
If you only buy the elbow, the filter, and the hose it's only $24 which is a third of their asking price.
All you need after that is clamps and that plug or really another way to seal that line up.
Nice video and thanks for the links to the individual parts!
I have a couple of questions for you because I noticed a couple of possible inconsistencies.
In the video you show that the heater hose is 3/4", which normally means that the inside diameter is 3/4"; however, the heater hose that you recommended from Amazon is 5/8" heater hose.
Did you do that on purpose?
Also, the "B020A4" that you see on the K&N filter is the mold number, and that is not always enough to identify the exact filter, because multiple filters can share the same mold number. For instance, the 62-1000 that you recommended has a 3/8" fitting, and the 62-1030 has a 3/4" fitting, and both share the same "B020A4" mold number.
I just wanted to double-check before I order parts...
Thanks again for the nice installation video!
#5 ·
16" x 1.5"
2 feet of line would be plenty but I can't find that short of a length online.
It's the same situation with the clamps, I think it would actually be better to source locally where you can buy a single clamp as I can't find a listing for a single one but only 10 but wanted to show what the user should be searching for.
I like the idea of the product and I hate to talk bad on a product made for our cars when there is so little aftermarket support for Outback's.
They do make well regarded lift kits and I think I even prefer their skid plate to primitives based on info I have available on the differences.
I just wasn't impressed this specific product and that can't be changed. If you're doing the install yourself it's not worth bothering paying for international shipping.
It's a breather filter, clamps, and some hoses. If you're NOT doing it yourself and will be paying a shop to do it I can see this product making sense.
Different folks, different strokes applies.
I like LP Aventure products. They may not be the cheapest, but I am willing to pay for quality.
I have the LP Aventure 2" lift kit and their skid plate, and I am very impressed with the quality of those two items.
On top of that, whenever I have had questions, the LP Aventure team has been quick to respond.
I am interested in the DIY version of this product because I like to tinker and I don't want to pay $66 for a breather filter, two feet of hose, an elbow and a couple of clamps...
Yep, definitely considering the DIY version...as much as I believe LP gives us quality products, the international shipping is not cheap, and the savings in this case are not causing one to lose anything...
I 100% agree with you.
I couldn't find a ton of info available on this product and even after looking at the picture I was hesitant to purchase for how simple it looked but decided to just send it and be done.
Hope it at least helps a few owners out there.
#15 ·
I purchased the K&N 62-130 vent filter on Amazon.
The heater hose and elbow were bought at the local Pep Boys.
The rubber insulated cable clamp and the hose clamps were bought at my local Home Depot.
Please be aware that I purchased the 1" version of the rubber insulated cable clamp because the 3/4" version would have been too small.
Glad I could help! Thanks for helping source all the parts too.
Except for the K&N Filter I'm sure I could find everything and for less at the local hardware/auto store.
Having to buy such large quantities online made it harder to source for less.
#21 ·
I have added this mod on my 2017 Subaru Outback. Thank you for the write up. Very easy to source the parts.
Has anyone else that has done this had issues with stuttering during acceleration?
It may be a coincidence. Maybe I need to relearn the ECU since I removed the battery to clear the P1449 code?
Thanks!
#29 ·
I second this question! Anybody know if this would work on a 2013 Subaru Outback? I just got CEL code P1449 (clogged canister filter) after my wife drove through some water last night on her way home from work. I would love to go this DIY route if it’s doable on my 4th Gen Outback, seeing as here in Central Florida we get tons of rain and lots of water on the road.
So, does anybody know if this is doable on a 4th Gen?
#34 ·
I found this thread very helpful when my Subaru was driven through a very heavy thunderstorm and threw a P1449 code. Testing confirmed I needed to replace the Vapor Canister Filter but I didn’t relish having to remove the Differential to access it. This product saved me.
I came up with a slightly easier and more elegant DIY solution by using a heater hose with a 90-degree bend. It eliminated the need for the plastic elbow and the need to cut it (and saved a couple hose clamps). I used a K&N 62-1030 filter (~$23 Amazon), a Gates 28476 heater hose with a 90-degree bend (4” x 18”) (~$12 Amazon), two stainless SAE 12 hose clamps (~$2 Lowes), and a 1” insulated cable clamp (~$2 Lowes). It worked great (see picture).
FYI - I also found that Advance Auto Parts sells the originally referenced Dayco ¾” Insulone 80316 heater hose by the foot ($1.29/ft). They also sell the Dayco 80674 elbow (~$3).
Thanks to the OP and everyone who contributed.
518453
#35 · (Edited)
Thank you very much for posting this video, it was very helpful!
I would like contribute a few details for anyone about to complete this excellent modification.
1. Do yourself a favor and get the Gates 28476 3/4" heater hose with the bend molded into it. (Don't confuse it with the very similar 28467 hose which is unusable for this application). This hose has a 4" long short side and a 18" long side. I cut off 1 3/4" off of the short side and 2" off of the long side and it fit perfectly. During installation there is a ridge that the short side will overcome which is easily done with a very slight amount of lubricant. It doesn't take much, I used slick honey but I think even saliva would work.
2. I was able to use a #10 stainless hose clamp to attach the K&N 62-1030 3/4" crankcase vent filter to the long end of the hose. I struggled using the number 10 hose clamp to attach the short end of the hose and opted to use a hose clamp that had a maximum range of 1 1/4" which was slightly larger and much easier, this was due to accommodating the above mentioned ridge.
3. I used a 1" insulated cable clamp to secure the long end of the hose but it required a bit of modification to be as snug as I wanted it, I would suggest using a 7/8" version of the insulated cable clamp which may be more difficult to source but much better for the installation.
4. I used the red plastic cap off the positive terminal of an automotive battery to plug the now unused hose that this modification replaces. Replacing the factory Subaru red clamp requires a bit of cyphering as it attaches in a very specific manner.
That's all I've got, thanks again.
#37 ·
Finished my install last night.
glad I had this thread for reference. After the install my eyesight was down, my ABS light was on, BRAKE light and a few other things (see below)
I was going to beg for help and then I saw someone’s picture above…. I forgot to reinstall an electrical harness I removed for easier removal of the breather tube 🤪
I would highly recommend not using the size tube I did for ease of bending the breather extension up into the wheel well. I ended up securing mine with zip ties to the top flange because the tube would collapse if I tried to use the factory bolt location
#38 ·
I have just done this, thanks @Brucey . The LP orange plug people are confused about comes from Aeroflow Performance Parts. We have a local distributor here DownUnder
It is just a tapered Dust cap ... SKU: MISC98-2025-12C ... I managed to purchase a single cap cost me a few cents. (Don't go by the size I quoted as this was the first on their list and it's the middle of the night)
total cost $21.25 USD or $35.21 local
#39 ·
Hello, I have an outback 3.6r 2014.. I brought the bypass valve.. So once I opened up the car to come across black and green holes.. The LP adventure company said that the bypass valve will not fit a 2014.. Has anyone have similar experience with this?? Or have found another way to fix their 2013-2014 to allow the car to drive through water?? Thanks
#40 ·
Hello,
