$40 Pinwheel for your intake!
2.5K views 15 replies 10 participants last post by  Crunch
Subaru Legacy Intake SUPERCHARGER!!!
Has anyone seen this before? Usually, I just see the Tornado-like things. However, with this one, the blades spin on a shaft supported by a space grade zero friction ball bearing! Space grade!!! Awesome!
I can't wait to get one! Oh, wait. I might need a qualified mechanic to install it...Nuts to that!
...Space grade pinwheel...fojeezy...:20:
LOL at the installation instructions. This thing looks like it will restrict more than produce air flow.
1. Remove air inlet hose located between air purifier.
2. Install the SuperCharger inside the air inlet hose.
3. If the SuperCharger unit is smaller than your cars air inlet hose, use the plastic ring attached to increase its diameter so it can fit in the tubing.
I'm going to buy three.
One for the OB, of course.
I'll need a second one so that I can disassemble it and get the space-grade ZERO friction ball bearing out of it. I've been needing one for a perpetual motion machine I've been building.
And the third I'll need for this other project I've been working on. I can't say anything now except that it involves a DeLorean and what I call a flux capacitor.
With gas prices what they are, you might want to try modifying your DeLorean to run an alternative fuel source...maybe plutonium. You'd probably get best performance if you got it to generate 1.21 gigawatts of power through nuclear reaction.
Brucey said:
Dont you guys pay attention in 80s pop culture class?
The Delorean is fueled by mr fusion. Mr fusion takes anything you throw in it and turns it into energy.
The first post is a scam.
Why then, would I need to steal some plutonium from Libyan terrorists by telling them I would make them a bomb but then send, in its stead, a fake bomb made out of parts from an old pinball machine? Oh well, there won't be any consequences to that.
Not a bad idea jeremy, heck i'm sure I could invent a cheap hunk of junk to slap onto a car and say it improves fuel economy, then sell it for big money.
Maybe a therapy electro-magnet that you slap on top of your engine computer chip, it should definately run different. Or how about an exhaust afterburner?
hmmmm.....
:27: :15: :4: :22: :22: :22:
